      10-17-2011, 12:32 AM   #58
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
18x9.5 et22 should be fine in the rear. I had 19x9.5 et22 wrapped in 275/30/19 T1R's in this pic and I had no rubbing issues. Keep in mind I had my fenders shaved and I ran -2 camber. I had lots of clearance so I later spaced the rear out 10mm and I still never rubbed on the street even while taking freeway ramps and going over railroad tracks. I only rubbed occasionally going over bumps and dips while pushing the car at autox events.
Judging by the rim clearance in the pic I'm sure you can put on more aggressive tires than T1R's if you are ok with running -2 camber.
