Originally Posted by filtercoffee
driver side front where the bumper cover meets the fender:
View post on imgur.com
that's where it rubs when I turn right. (well, used to rub)
here's the rub point when I turn left:
michelin pilot a/s 3+. probably should have stuck with 235. oh well. I hope people can learn from my mistake. and any advice is appreciated.
Mine are rubbing in the same spot. The clip that holds the bumper/fender together very near the rub spot is broken. Not sure, but suspect this rubbing may have broken it.
I currently have 225/45/17 tires on 17x7 rims 40mm offset with 20mm spacers. I just ordered 15mm spacers in the hopes this will cure it.
