04-26-2012, 08:46 AM
#11
Drives: 2004 Z4 3.0i 6-speed Sport
Originally Posted by FSHFACE
Follow the steering shaft down from the wheel and you will come to a shinny shaft. This is the inner race of the bearing. The bearing is inside the upper part of the column. When you pull the telescoping wheel in and out it slides up and down this stationary shaft. I used white lithium grease on my fingertips and coated the shinny part of this shaft. Easiest when the wheel is all the way up and pulled all the way out. Oh and I took the lower half of the steering column cover off too. 2 screws. One near the wheel unlock lever and one on top by the instrument cluster. Then it pops apart. Then just work the grease into the bearing by pushing the wheel in and out while turning the wheel side to side. Hope that's clearer.
Perfectly clear thanks.. .
