      10-10-2015, 04:34 PM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
INPA doesnt flash ecu's
BMW uses other programs for that. They have 2 but I'm not sure about the difference.
The bmw flash tools are not exactly user friendly.
INPA is diagnostic with some adjustment on components.
But if you can read your cpu with inpa, your ecu can probably be saved.
I have no idea if the bmw flash tools will be able to handle your backup file. (I doubt it)
