Originally Posted by Dammmittt
Why 70 mph? I'd like to see you do dyno runs at verying wind speeds. 70 mph seems like a random number. I'd like to see some schematics on the design too...is it just a scoop attached to a constant diameter pipe or do you have a converging throat area to increase flow speed/pressure as it enters the combustion chamber?
70mph is just what our dyno fan is rated at. Our fan flows 70mph at 8ft from the front of the car. We do all our hp tests with the hood closed. The factory air ducting is very efficient but relies on vacuum to provide air to the engine. There is a small cup with 1/4 to 1/2 of a velocity stack. The scoop pictured above is the first prototype (laidback has been asking us for some time to make him one.). As with our scoops for the m5 and m6, the final design will be done on the car on the dyno. Its hard to tell from the picture but the scoop flares outward to provide a larger surface area to collect air. It them flares inward to help with air velocity going into the factory air duct. We conduct our tests in an "open house" manner so all are welcome to come watch our product testing. If the stuff works, you all can see. If it doesnt work, you all can see too. Its our priority to provide a good, funcitonal yet cost effective product to our customers.
