Originally Posted by ZEDMFOUR
Well I pulled the trigger. Just bought a set of Diablos from RE's website. Hope they are in stock. Be on the lookout cause if they are too loud or drony someone will get a chance to buy a set slightly used for $950 plus $40 frt.
Just a note of caution ... I ordered a set of Diablos off their site in August or so, they were out of stock and didn't come till November. No biggie there. However, when they got their new batch in the manufacturer forgot to weld on two nuts. When you remove your OEM cans you'll see one nut on each can that is welded on and you'll have to go to a local hardware store and buy two nuts that work.
View post on imgur.com
I put small red boxes around where the missing nuts will be. This is assuming the haven't fixed it.
