      02-12-2013, 12:12 PM   #7
ApexWheels
ApexWheels's Avatar
1439
Drives: M3
Originally Posted by psygnosis View Post
It's all Z4Ms, do these still fit the non-M Z4?
Or no M, no care?
The EC-7's will absolutely fit on your Z4. There are actually a couple of new fitments in the EC-7 that would allow you to use a wider 265/35/18 rear tire where you could not before. With the ARC-8 wheel you were limited to using an 18x9.5" ET35 which is still wide at 9.5" but the offset is a little low if you are looking to use a tire wider than 255 width. The EC-7 is available in a new 18x9.5" ET43 size that lets you use that wider rear tire but still retains the wheel concavity people look for. In the front you can use our 18x8.5" ET35 or possibly other wider wheels with the required modifications.
Unfortunately we do not have any photos of EC-7's on a non-M Z4 at this time but feel free to give us a call with any questions you may have about fitment or the wheels.
