      04-23-2014, 11:18 AM   #3
Beedub
Originally Posted by nekky View Post
The rear will fit fine. I run a 10.5" +22 in the rear on a 275/35/18 RS3 and I have no issues whatsoever. I am lowered quite a bit but plan to go down even lower. Running KW Clubsport.
Don't listen to them. It works fine!
i always worry when i see posts like this....
I'm running a 9.5" rear ET23 18", and let me tell you this is literally FLUSH with the fender, so when i read "it fits fine" I'm not sure what your/my idea of fine is, are we saying it'll bolt and and no rub with lots of camber out back, because let me tell you an 10.5 in rear ET20 WILL rub when used properly and under full compression......from how my current setup fills the fender i don't see how it can't tbh???
educate me nekky!!
