      11-22-2012, 12:35 AM   #12
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
I was thinking I should clarify what I was feeling.
At start up when cold I got an erratic idle. It would vary between 500-750RPM. Once warm the idle would be steady in speed, but rough in texture (booming vibration, water in water bottle made lots of ripples).
After replacing the spark plugs still get a little idle variance at start-up, but the engine ran so much quieter. WOT accelerations were the same speed but felt about 60% smoother. When idling warm the engine was insanely quiet.
Error codes obv points to VANOS or coil pack problems. BMW's coil packs kinda suck, but I wouldn't replace them as a maintenance item, only if/when they go bad.
