Here's were I'm at. I'm can compare other shops (if y'all have any others to recommend) but this is the quote that I'm looking at currently. I need to shave quite a bit off of this to make it work. What do you guys think are the bare essentials to have done on a pulled engine from another vehicle? (I am unsure of what vehicle or the condition it was pulled from, I can only assume it was an M3 as it does not have the Z4 oil pan and has 80,000 miles on it).
Breakdown of Services on Used Engine
Code:
ACTIVITY AMOUNT
crankshaft-Polishing
Polish S54 Crankshaft Journals,
1 @ $150.00
CPS54CSTM
Set of 6 Shelf Mahle Pistons S54 Includes wrist pins and piston rings. 87.5mm bore, 21mm wrist pin, 11.5
CR, 1 @ $965.00
S54WideRodCarrillo
Reuse OEM Rods
0.00T
LRD-S54 MainBearingSet
Genuine BMW Main Bearings - Sizes Specifically Determined for Each Engine Application, 1 @ $428.52
Our Stage One Cylinder Heads feature the following:
Complete Disassembly & Cleaning
Comprehensive Leak, Crack & Pressure Test
Inspect All Components For Irregular Wear
Our High performance Five Angle Valve Job
New Valve Seals
Trueness Checked & Resurfaced Mating Surface
Unshrouding of Valves
Attention to Potential Hot-spot Areas and Chamfering, 1 @ $780.73
ACTIVITY AMOUNT
Labor
Machine shop labor on Block (87.5mm Pistons):
Bore Cylinder Walls to 87.5mm Mahle Piston Size
Hone block cylinder walls
Hot tank block
Surface deck, 3.8 @ $125.00
11 12 7 831 920
Genuine BMW Head Gasket Set - Without Head Gasket, 1 @ $356.93
11 12 7 835 918
S54 Head Gasket (.64 mm), 1 @ $75.95
11 11 0 302 722
Genuine BMW Lower Engine Gasket Set:
Oil pan gasket
Crank and intermediate shaft seals
Seal cover gaskets
Miscellaneous o-rings and gaskets, 1 @ $331.75
331.75T
S54CPVOR
S54 Constant Pressure Valve Viton O Ring, 1 @ $4.95
4.95T
11 23 1 402 608
Genuine BMW S54 Crankshaft Pulley Bolts, 4 @ $6.15
24.60T
11 12 7 831 862
OEM Head Bolt Kit, 1 @ $59.36
11 11 2 244 286
S54 Main Bearing Cap Bolt, 14 @ $4.11
S54LRDCamBoltRepairKit
Lang Racing Development Camshaft Bolt Upgrade Kit, 1 @ $14.95
11 31 7 830 159
Timing Chain Rail (Tensioning Rail), 1 @ $17.49
11 31 7 830 569
Timing Chain Rail (Slide Rail), 1 @ $59.64
11 31 7 836 344
Timing Chain Rail (Slide Rail), 1 @ $18.01
11 31 7 836 441
Timing Chain Rail (Tensioning Rail), 1 @ $36.03
BS021
Beisan S54 Vanos Seals Repair Kit, 1 @ $60.00
BS024
Beisan S54 Vanos Sealing Plate Repair Kit, 1 @ $10.00
BS025
S54 Vanos Oil Pump Disk (300 Refundable Core Charge), 1 @ $150.00
ACTIVITY AMOUNT
Labor
Rebuild of Vanos Unit Inlcudes:
Installation of Internal Vanos unit seals
Replacement of Vanos Plate Seals
Installing Oil Pump Hub, 2.8 @ $125.00
350.00
Labor
Long Block Tear Down, Inspection, and Reassembly Labor Includes the Following:
Complete Dissassembly and Inspection of Longblock
Block Inspection, Measuring Main Bearing Clearance and Installing Crankshaft
Measuring Rod Bearing Clearance, Balancing Rod and Piston Assembly
Measuring Piston to Bore Clearance
Measuring Piston Ring Gap and File to Fit as Required
Piston and Rod Installation, Rod Bolts Torqued to Stretch
Cylinder Head Installation, Setting of Initial Valve Shim Clearance
Installing VANOS Unit and Setting Cam Timing
Installing Valve Cover and Oil Pan, Replacing All Gaskets, 26 @ $125.00
3,250.00
S54LongBlockCore
S54 Long Block Usable Core For Rebuild
Prices for Partial Core Refunds if Applicable:
Cylinder Head - 850
Crankshaft - 500
Cams - 200
Oil Pan - 250
Valve Cover - 150
VANOS Unit - 400, 1 @ $2,200
The other assumption is that I can just purchase this engine for around 3,500 and trade in my core components for around 2,200 and net 1,300 for a used engine and tackle whatever problems may lie ahead of it as the come with some rainy day fund specifically for the engine. I'm not sure if this is the best option, but it's the only other I can think of. I'm still working on reaching out to the right folks at BMW of NA. If y'all have any contacts there I would greatly appreciate a lead or two.
