Originally Posted by FD3S
The offset of those wheels as I read from the BBS website is:
8,5x19 offset 35
9,5x19 offset 40
and the bolt circle is 5/120 as far as I know.
If those sizes are as you've indicated, then there's no issue up front. You would want around a 25 offset in the rear, which means you will need to add a 15mm spacer to the rear if you want to make these wheels work on the car
