      04-04-2013, 12:51 PM   #60
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
I'm ready to pull the trigger on a set of ARC-8s and PSS tires, but still unsure on a few things.
Love the look of GothM's car here.
I'm on H&R springs too, so assuming the F: 18x9 et42 245/40/18 and R: 18x10 et25 275/35/18 combo would work and won't rub - without the need for spacers or additional camber?
When I install coilovers/camber-plates next year, can I keep these same wheels?
GothM mentioned he uses a 15mm spring pad. Anyone know where can I pick these up?
What length valve stems will I need for the new wheels?
36111095375 / 36146792829 43mm (RDV 001)
36111096449 / 36146792830 48mm (RDV 002)
36111095374 / 36146792828 49mm (RDV 003)
36111095373 / 36146792827 51mm (RDV 004)
Besides the ability to rotate; what are the advantages of the square setup?
