      04-21-2021, 02:22 PM   #75
F360C
Drives: E86 S54
Originally Posted by maupineda View Post
I have reached out to them and got a very detailed answer, so yes, the diff is different and to open you need a special tool (can be made up) and drill a steel pin/ball out that secures the cap, then unscrew the whole cap.
The Z4M uses the V2 of this design, as well as some late production M3s, and so is shared with the E92 and E60, and it has an additional set of clutches, so I think V2 can handle more torque as it was used on the V10 engine.
To the above point, backlash and mesh can be skipped if no change to the gearset. they said 100% of the time they checked it both come back on point. if you change the gearset, shimming the carrier is all that is needed. they really seem to know these diffs inside out, something I did not get with the US suppliers. I mean, changing bearings and crush sleeve is nothing special other than the intese labour and specialty tools required for it.
Bringing this old thread back but has anyone rebuild the GKN2 LSD in our cars and can share the process for getting the LSD itself open?
maupineda You don't happen to still have their detailed response you could forward me?
So close to pulling the trigger on the RacingDiff clutch pack but want to know what I am in for in terms of install.
07 Z4 M Coupe AW/IR
