Originally Posted by v3.2mc
there won't be any rubbing depending on the tires you choose.
the 19's are wider than the 18's. i think you were meaning by offset though, in which case... yes, the front track for the 18's is larger than that of the 19's.
e82/88
*18" frt: 7.5" et49
*18" rear: 8.5" et52
e89
*19" frt: 8.0" et29
*19" rear: 9.0" et40
e90/91/92/93 (and e85/86 non-///m )
*18" frt: 8.0" et34
*18" rear: 8.5" et37
*19" frt: 8.0" et37
*19" rear: 9.0" et39
lots of guys across the pond are on these in 19" form. search on z4-forum and you should be able to find them. Dadoke's car comes to mind.
also, check on zroadster... many 313's there as well.
Has ANYONE got some good photos of this setup with the 18in 313???
Ill order it if it looks good as it seems it will work.
