Originally Posted by XMetal
Stock for ///M are:
225/45ZR18 front
255/40ZR18 rear
As long as the tire doesn't "rub" or comes in contact with anything during suspension compression, you should be fine. There are a few people running your indicated size without issues. However, some do report "rubbing". So, it may depend on the tire model as not all 275s are created equal
So if you want to go 19" it should be
2XX / 40 / 19
2XX / 35 / 19
