      03-24-2013, 10:57 PM   #29
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
Originally Posted by jdtorreride View Post
Thanks for the this thread on bumper removal. I'm in the process of removing my coupes bumper and have of couple of questions before I continue with the removal. First under the lower edge of the bumper I removed a total of four 8mm bolts which are located on the underside of the fangs, two on each side. I also removed three screws located between the fangs. Are these the correct and screws/bolts that you are referring to? Also I attempted to pull off the bumper by the headlight with a good amount of force and it did not budge. Are there any tricks that might help me get the bumper separated from the fender. I did grab the bumper below the clip that holds the two together. Should I pull forward, down or out to get them to separate? How about carefully prying the two apart with a screwdriver?
Just pull out in a horizontal movement away from the fender, wiggle it a little back and forth. Eventually it will come off. Do not use a screw driver - you might end up breaking those fragile brakets...
2007 BMW ///M Coupe
