Coding for Alarm
I coded my alarm last night and everything seems to be working well.
By default in the E85, the clown nose and arm chirp are disabled. For those without an alarm, change option "DWA" to "aktiv" in NCS Expert and your clown nose will blink. When you add option $302 for the alarm to the vehicle order (VO), DWA gets turned automatically.
I also turned on comfort closing to put the top up from the key and a few other things while I was in there. Coding is actually quite easy on the E85 compared to my F10 with the hardest part being getting the software installed correctly on your PC.
If anyone in the Boston area needs help getting your alarm working, shoot me a PM
