Originally Posted by dubsesd
To change the bulb, you need to turn your wheels or take them off, remove the small plastic access panel in the fender liner, and open the headlight backing. You will see a silver square igniter that has a wire holding it. Release the wire and twist the igniter off. Replace bulb and reverse the steps
Thanks for yours advice, very helpful
