For those familiar with NCS Expert you can disable auto-lock when you drive away with the following in your GM5 module:
VERRIEGELN_AUT_AB_X_KM/H
Set this to nicht_aktiv to disable entirely. To clarify, when you disable this you will have to lock your doors manually afterwards.
Or you can disable it by specific key with the following lines:
VERRIEGELN_XKM/H_SENDER_1
VERRIEGELN_XKM/H_SENDER_2
VERRIEGELN_XKM/H_SENDER_3
VERRIEGELN_XKM/H_SENDER_4
Set any of these to nicht_aktiv to disable the feature for that key.
As others have noted, there's no real way of addressing the double-pull issue without a workaround. Disabling the "drive-away lock" feature is just a band-aid solution to those who still want to lock their doors without the double-pull unlock.
Hope this helps.
