Thread
DIFF fluid Change
09-26-2012, 08:21 AM
shakemyhand
Drives: 2007 Z4 Roadster 3.0i
Originally Posted by
lstratos
I just did this for my 07. The steps are exactly the same as your, nothing has change.
I had plan to just change the drain plug out to a new one but before I started, I found this dimple magnetic replacement plug, so I end up using my new drain as my filler and the dimple plug in the drain.
The dimple plug is very very strong, was really hard to get into the hole (insert thats what she said joke). The magnet kept sticking the body of the diff and took a little time to plug it the drain hole and screw in..
I end up using redline gear oil. The dimple plug was pretty expensive.. around 30.
As you guys can see my bottom is pretty rusted.. salt of north east can do that... Not driving it through snow or salt this year
Should I sand that off and spray anti rust on that ?
Thank you for the pictures and all the good information. Mike
Quote
shakemyhand
View Public Profile
Find More Posts by shakemyhand
