Originally Posted by drbvac
Now I have the dash off - it was to see if I can mount a boost gauge
The pods are not available for the Z - even the vent pods and the dash mounts look add-on
Speedhut will make a gauge all custom - dial, bezel, font, light and even a logo 2 1/16"
I will try and show the one I was thinking of.
So if I put it where the black cap is -- same size - same view through steering wheel from my sight line where the full dash picture is.
I never would stare at a boost gauge like you would look at a tach so I would glance once and a while - so
Good spot.
I think a AFR gauge is more important to monitor,you can always get a boost gauge with a memory and install it down low.
What if you put the gauge on the A pillar?
