      02-27-2016, 12:17 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm guessing you removed the door to get access to the 2 torx screws underneath?
After my failed attempt to remove the door I found it is possible to get those out with the door still attached, just not easy.
Not sure which is more of a faff. Taking the door off, or removing the screws 1/4 turn at a time.
