Originally Posted by Beedub
definatly look into re-inforceing the stock intake manifold.... it will take boost and save you a fortune, these fancy cast intakes are great but are a big chunk of the costs of FI and at low boost levels arnt really needed imo!!
Agreed!
I'm not sure how much boost the stock manifold will take abuse on though. I've seen other blow them with relatively low boost (under 10PSI).
Mike at Maxpsi is working on a ECU tuned kit for the E46 M3, using the stock S54 manifold, and he will definitely let the community know what the limits of that design is!
Again guys, good luck and happy boosting!
