Yes, thanks - that's what I elected to do. After fretting a bit, I removed the plastic cover and found that they hadn't bottomed out at 20'lbf.
Along with piece of mind in adjusting the valves, engine seems to be much smoother - should be after:
Oil change and filter
Intake, cabin and vanos filter
Valve adjustment
New plugs and ignition coils
New belts, idlers and tension pulleys
Along with brakes, diff trans and brake fluid change next weekend.
