      06-15-2012, 05:56 PM   #1
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
444
Drives: E30 M3, F10 M5
APEX EC-7 wheel Pre-Order
APEX is proud to introduce its new EC-7 wheel. This new wheel addresses the concerns of more and more racers and track day enthusiasts: long term durability, fit and performance. With the increase of faster and heavier cars being used in racing, HPDEs, and spirited driving, the EC-7 was designed and engineered to handle extreme abuse on track and street, offer a wide range of direct fitments, while producing a lightweight wheel. The new features offered make the EC-7 the perfect compliment to the APEX ARC-8.
An optimized car setup begins with the perfect wheel fitment. Without the perfect offsets, maximum tire widths and the potential of your car are always compromised. With this in mind, the EC-7 has three unique face profiles ranging from shallow to deep concavity resulting in 13 unique 18″ sizes. This wide range of fitments allows for vehicle-specific caliper clearance, offsets, and tire widths, creating the most optimal setup possible.
Available Sizes and Weights and Retail Pricing:
  • 188.5″ ET45 19.55lbs $294
  • 188.5″ ET35 20.10lbs $294
  • 189.0″ ET42 20.75lbs $299
  • 189.0″ ET31 21.25lbs $299
  • 189.5″ ET58 20.65lbs $319
  • 189.5″ ET43 21.55lbs $319
  • 189.5″ ET35 21.70lbs $319
  • 189.5″ ET22 21.75lbs $319
  • 1810″ ET43 21.95lbs $329
  • 1810″ ET33 22.50lbs $329
  • 1810″ ET25 22.45lbs $329
  • 1810.5″ ET27 22.50lbs $349
  • 1811″ ET25 23.35lbs $359
Available Finishes:
Race Silver
Anthracite
Satin Black
EC-7 Design Details
The EC-7 adds 7 new BMW sizes not available in the ARC-8 design. The 3 face profiles offer maximum concavity and reduced weight. This avoids the common adaptation of a single face profile for unintended fitments or dependency on spacers.
The EC-7′s spoke profile has been designed with a curve to provide additional caliper clearance. It can clear a BBK spacer free on applications where the ARC-8 could not. A significant improvement to the EC-7 is the increased barrel clearance that now allows for the 18″ version of this wheel to properly clear the Brembo 380mm BBK.
Just like the rest of the APEX wheel line, the EC-7 is once again produced using the Flow-Forming technique. Flow-forming, which has also been called roll forging or spin forging, produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the barrel, which has the greatest impact on rotational mass. Weve produced an even stronger wheel by combining the strength of the lightweight barrel with a more robust face design. The EC-7 welcomes endurance racing and potholes.
Designed for BMW applications, the EC-7 accepts TPMS sensors, factory lug bolts or stud conversion kits, and OEM roundel center caps. All wheels come with APEX center caps.
Warranty Summary:
2 year Structural, 1 year limited finish warranty guarantees wheels will be free from defects in materials, workmanship and paint finish under normal and reasonable use.
Misc:
  • Comes with carbon-look APEX center caps
  • Accept OEM Roundel center caps
  • Accepts factory lugs and wheel locks, or stud conversion kits
  • Accepts TPMS sensors
