      01-16-2019, 08:02 AM   #13
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Originally Posted by Shorts View Post
Fellas,
I'm gearing up for at least one track day this spring and after some thorough research in this forum and some other googling bought a set of DTC-60 front and rear. I'm planning on using RBF600 fluid as well.
What are thoughts on buying a set of rotors to use solely with the DTC-60 and keep the current rotors for the street oem-grade pads? I'm wondering if I should be concerned with pad deposits on the rotors?
I use DTC-60 pads front and rear as well with stock rotors. I find the 'cold' braking driving to and from the track cleans off the pad deposits so I don't experience any braking issues or vibrations. These pads are quite aggressive when cold so by the time I get home I can swap back to OE pads.
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
