Originally Posted by Beedub
thanks for the info..... easy home DIY???
so we use the same half shafts as the m3?? i thought they may be slightly shorter, thats good info ;-)
Yes same as the M3. DIY not to bad,you need to remove part of the exhaust and sway bar, you defiantly need the right tool to remove the spindle form the hub to get the half shaft out.
