Car jacking
I think the OP meant that if the front of the car is lifted via ramps and the back of the car is sitting on the ground, then the car would be slanting downward. It wouldn't be level as if it was sitting on a flat surface.
So, let's assume he drives the front of the car up on ramps. How does he then get the back lifted near the same height in order for the oil to drain well?
