Originally Posted by Finnegan
went up to 245/275
Finnegan, please confirm that the Michelin Pilot SuperSport tire sizes you're using are 245/40R18 front and 275/35R18 rear.
I understand that you are running them with the stock Z4M rims. Is your geometry set stock, or modified (e.g. more negative camber front, or spacers). Any issues such as rubbing / interference with the stock geometry setup? Thanks.
