Originally Posted by zkeeper
Second that on not sure what "better results" is defined as. You have 68K on it, and unless you have done a tear down to check journals and bearings etc, not sure what better results you need. The secret to better, or perhaps longer results is more frequent oil changes...and the BMW oil will be fine if not more than fine. If you wish to compete in the car, that may be a different story...so not sure what results you are looking for. Good luck on the quest...
+1. I like castrol full syn
