Originally Posted by intoflatlines
Well apparently with 9" ET42 wheels and 245 tires that run wide up front, even one camber washer makes it rub on the strut. Oh well. Spacers or camber plates for me I guess!
You can probably run a 5mm spacer. We have 245s on 9" with ET37. If you go 10mm spacers, w/o lip, get Turner Hub Extenders. Hubcentric wheels require the lip. I'm a bit OCD about that, so I went with the extenders with a 5mm spacer.
