I replaced mine with a modified one, because I was afraid the hose wouldn't easily reach.
Turns out it would have.
I used a "hose squeezer" to keep the leakage to a minimum, and did a fast swap.
Didn't lose any fluid except what was in the volume of the CDV.
Just did a quick bleed to work that one bubble out.
Much smoother shifts from 1st to 2nd, and less clutch wear. Definitely a "must do" mod.
