      11-25-2011, 07:09 PM   #39
sabbanick
Drives: 08 SBM M coupe
Matt thanks for putting together the website and allowing us to host/share data through it.
Install is complete but I'm having issues installing windows XP on my computer so can't access the can bus info just yet. Tempted to just buy a cheap windows based laptop and be done with it.
Install went ok, the hardest part is taping into the ECU wires...there is no wiggle room. I actually shaved down the wire taps to make them as small as possible.
The only thing i am not completely thrilled about is the hardwire power source. Ideally I would like to have a switched power source, so I don't have to worry about killing battery should I forget to disconnect the wire to the solo at the track. If anyone knows of a switched 12V source by within the ECU box please let me know.
Frank thanks again for the DIY, I could not have done this without it.
Soo mad I can't install the OS on my computer to check everything out!
