      03-11-2010, 11:07 AM   #16
Chris04Z4
Drives: 2004 Z4 Roadster 3.0i
Originally Posted by Shipkiller View Post
To check the DISA, just pull the electrical cable to the DISA. If the rattling stops, there you go. That is the way I have seen most others figure out the issue.
unless the shaft is broke inside the flap like mine... the rattle will continue because its just freely hanging there... no tension in the flap. I did try this when i had mine break.
