After reading and digging multiple push start button guides. I found that same picture you posted of the pins on the button. Why are the pins wired to the ignition power? Do you mean the power wire coming off the relay? That makes more sense? Doesn't the power for the lights need to come from the ashtray? Or does the ignition power wire work the same?
