I ended up buying a dedicated autocross 17" square set up from Tire Rack for my Z4M (Kosei K1 in 17x8.5 et 40 with RS-3 tires 255/40/17) and am wondering about wheel spacer needs.
The car is all stock suspension wise, with the alignment pins going to be pulled when the new set comes and is aligned to get more negative camber up front.
Tire Rack is providing 18mm spacers and longer bolts for the rear, but I am wondering if a front spacer is needed. Checked on willtheyfit.com and it looks like they will push in 4mm to the strut. Would there still be enough clearance that suspension rub will not be an issue?
Thanks!
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
