      07-15-2010, 11:37 PM   #51
wildag
///M'n it Up
wildag's Avatar
Drives: '06 ///M Roadster
Originally Posted by VinnieAces View Post
Anybody?? Cmon some of you have to of done this mod, just at least lemme know which route you went and why
The Zeckenhaus CDV replacement looks exactly like the OEM CDV from the outside. It however doesn't have the same internal restrictor.
You only need to use a CDV replacement if your car is still under warranty. Otherwise, there's no point in paying money. You can simply remove the CDV if your car is not under warranty.
Its the same effect either way.
