Originally Posted by itdnwiwbp
Where did you get the wire protector. I'd like to go the same route just to make sure everything is ok down below.
You can route the wires like this (took the pics in crfine88 build up thread). You don't need to modify the o2 sensors wires, they are long enough if you reroute them on the driver side of the transmission tunnel.
