Thread: FAQ Thread
      04-20-2010, 03:33 PM   #3
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
I had started a notepad file that contains a lot of good info like you talk of. Here is a copy & paste of it. I'll try to go back later and clean it up a bit. If you see something that is incorrect please let me know. Also, If I quote you and do not put you as the source, I'm sorry, Let me know and I'll fix that. I am not trying to "steal" your work. Some of this info may be opinion based. I basically grabbed it from threads and made a little cheat sheet for myself.
AUX-in for the stereo was added in 2007 but was not in 2006 cars.
3.2L/198
HP @ RPM
330 @ 7900
Torque @ RPM
262 @ 4900
Fuel Tank
14.5 Gallons
Motor Mount Bolts Issue
Bolts needed are:
M8X26mm with 1.25 pitch 10.9 Grade
M8X35mm with 1.25 pitch 10.9 Grade
M8 Hardened Washers
Oem replacement bolts Part # which are 8.8 grade are:
07119905724 M8X26mm
07119905533 M8X35mm
*these come with washers*
McMaster-Carr Part numbers for comparable bolts are:
90854A167 M8x25mm (1mm shorter than oem)
90854A172 M8x35mm
*note* they are only sold in packs of 25*
91812A230 Wedge Lock Washer (Nord-Lock SS washers that prevent loosening)
*note* Sold in packs of 5
Torque to 21 N*m
Realoem shows 6 of the M8X26mm & 2 M8X35mm
http://www.realoem.com/bmw/showparts...64&hg=22&fg=05
Link to more info:
http://www.bimmerfest.com/forums/sho...9&postcount=42
http://www.zpost.com/forums/showthre...=328626&page=2
Thanks to Ron Stygar & others for providing all this info.
FAQs How to's
http://www.bimmerfest.com/forums/sho...d.php?t=130986
Determining number made
http://www.zpost.com/forums/showthread.php?t=235232
Coupes, Worldwide: 4,275, North America: 1,815.
Roadsters, Worldwide: 5,070, North America: 3,042
Source - BMW Car magazine, Nov. 2008 issue, pp 9.
Aluminum hood
Stock Tires:
225/45ZR18
255/40ZR18
Stock Wheels
Front 18X8.0 ET42
Rear 18X9.0 ET30
Style 224M
Stock Brake Rotors
Front:
13.6 x 1.10 inch
Rear:
12.9 x 0.79 inch
The size most of us run on the stock wheels is
front:245/40-18 and rear:275/35-18.
Final Drive Ratio 3.62
We have the same differential that is in the E46 M3
More info on swapping in 3.91 or 4.10:
http://www.zpost.com/forums/showthread.php?t=287976
Curb Weight 3230 lbs
OEM Wheel Weights
Front = 24.75 lbs.
Rear = 25.88 lbs.
http://www.bimmerfest.com/forums/sho...d.php?t=167236
With the Z4 M, the ideal shift points are at redline with the exception of 5th to 6th, where it's 500 revs sooner
http://www.bmwmregistry.com/
The gearbox is from the 3.0si rather than the E46 M3
DIY clutch stop mod
http://www.m3forum.net/m3forum/showthread.php?t=179858
ZHP Knob
http://www.trademotion.com/partlocat...catalogid=4462
Z4M Production and Other Interesting Info Thread
http://www.zpost.com/forums/showthread.php?t=201969
Nav Tweek
http://www.xoutpost.com/electronics/...avtweak-2.html
http://www.m5board.com/vbulletin/e39...k-dummies.html
Camber
http://www.zpost.com/forums/showthread.php?t=339138
http://www.zpost.com/forums/showthread.php?t=321359
http://www.turnermotorsport.com/html..._ID=TSU3690036
Approx what can be adjusted
front -1.00 camber stock with pins
front -1.5-1.75 stock without pins
front -2.5 with shims from turner
Suspension Guide
http://www.zpost.com/forums/showthread.php?t=44325
