Originally Posted by Finnegan
Original battery? Even it not, I'd start there.
Check the connections for tightness/corrosion. Get the battery checked.
This is common problem with the battery, easiest to test for, and a quick fix if it is battery related.
Just changed battery couple months ago with one from sears. Ill check the connections after work. Should I get battery tested at autozone? She starts up without hesitation on a cold start (car is parked outside condo).
Also read it could be MAF. Really hope that is not the case.
