Originally Posted by Mirko
Anyone know, would the below fit??
-18"x8"
-5x120 bolt pattern
-Offset: +20
- 225/40R18 Front rubber
- 245/40R18 Rear rubber (would 255/40/18 fit?)
Really cheap rims for winter that I think would clear a BBK. Would come out cheaper than spacers. Thanks
The rear will fit without a problem with either 245/40-18 or 255/40-18. The front may be a problem, most likely rubbing on the inner liner by the headlight at full lock and possibly on the fender at full suspension compression.
For winter tyres and wheels I run 225/45-18 all around on +40 front wheels offset and +20 rear wheels offset.
