Originally Posted by aestheticstorm
Point taken about not even needing a pad upgrade but I know I need to do the fluid so I might as well just upgrade the pads and lines. Any recommendations for pads? I'd like to use them for street as well. Why do some folks swap?
Stoptech pads and lines. Available here...
http://www.zeckhausen.com/BMW/Z4-M_Coupe_Roadster.htm
Fluid
http://store.zeckhausen.com/catalog/...facturers_id=8
Folks that swap are typically using aggressive pads that operate at high heat levels and don't lend themselves well to daily driving. In addition they can be noisy. I have the Stoptech's. I don't drive in cold weather; another consideration is the operating range of the friction material.
2006 Z4MC - #LL93158
