Originally Posted by tikamak
Originally Posted by gmd2003
Did you direct wire the Aeromotive for the power it needs ? If not that may be why it was having issues . The stock fuel pumps wires are not good enough . I'm running lean up top now and believe this is the issue .
I have this issue with the stock fuel pump when i have low fuel in the tank.
What is your fuel level in the tank when you are having a lean condition ?
I believe that the proper solution is to install a fuel catch can with the stock pump and use the aeromotive to supply the fuel to the fuel rail.
I'll post up pics in the coming month.
Guys this was with a full tank on the dyno .
