      09-27-2012, 02:29 PM   #24
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Still for sale?
Side note: I have an electric cut out on my VR4 welded into a test pipe, well worth it. I even put a little time wiring the switch up inside of the covered accessory socket so you cant see it. The looks people give you when you go from quiet to loud to quiet are worth it, plus on a turbo car is reduces lag. Just have to be careful to have the cutout not stick out too much under the car, mine was welded to y pipe in a weird angle that makes it hang lower than it should.
