      09-14-2014, 06:58 PM   #3
pungo
pungo's Avatar
The only change I made was to change the value of TDR from nicht_aktiv to activ. Give it a try and report your results.
I believe TDR stands for "TRAKTION DIFFERENZ REGELUNG" which google translated to "TRACTION DIFFERENTIAL SYSTEM".
BMW defines DTC as:
Dynamic Traction Control (DTC) is a sub-function of the Dynamic Stability Control (DSC) system that can be turned on and off. DTC has two major roles: to regulate traction and to enable sports-style driving while providing active stability control.
The DTC also makes driving on snow and ice-free roads more dynamic. When activated, the DTC allows sporty drivers more room to manoeuvre around curves than the Dynamic Stability Control and even permits controlled drifts. The driver retains complete control over the vehicle in every situation and the Dynamic Stability Control’s stabilising measures remain active even when the DTC is activated.
There are some other parameters than may reduce the DSC intervention but I didn't change any of them.
Here's a few of interest:
UEBERSTEUERN_MUE_0_2 - OVERSTEER FRICTION COEFFICIENT 0 2 [DATA<128 ? COEFFICIENT=1.5+(DATA/128) : COEFFICIENT=1.5+((DATA-256)/128)]
UEBERSTEUERN_MUE_1_2 - OVERSTEER FRICTION COEFFICIENT 1 2 [DATA<128 ? COEFFICIENT=2.5+(DATA/64) : COEFFICIENT=2.5+((DATA-256)/64)]
UNTERSTEUERN_MUE_1_2 - UNDERSTEER FRICTION COEFFICIENT 1 2 [DATA<128 ? COEFFICIENT=2.5+(DATA/64) : COEFFICIENT=2.5+((DATA-256)/64)]
UNTERSTEUERSCHWELLE_2 - UNDERSTEER THRESHOLD 2 [DATA<128 ? COEFFICIENT=2.5+(DATA/64) : COEFFICIENT=2.5+((DATA-256)/64)]
GEARMOMENTREGLER_MAX_HA_2 - GEAR-TORQUE CONTROL MAXIMUM REAR AXLE [DATA<8 ? PERCENTAGE_%=(DATA*4000)/1024 : PERCENTAGE_%=((DATA-16)*4000)/1024]
GEARMOMENTREGLER_MIN_HA_2 - GEAR-TORQUE CONTROL MINIMUM REAR AXLE [DATA<8 ? PERCENTAGE_%=(DATA*4000)/1024 : PERCENTAGE_%=((DATA-16)*4000)/1024]
