      01-06-2017, 04:16 PM   #22
GuidoK
#buildnotbought
GuidoK's Avatar
10877
Drives: Z4 3.0i ESS TS2+
Originally Posted by dc_wright View Post
If you were being properly AR, you'd drain the old oil, do a fill, run the engine for 20-30 minutes, and then drain that oil so that you've flushed the old oil out, then refill.
With 20-30 min running you wont get to refresh the oil in the lifters....
That will take days/weeks.
But for a z4m you will refresh the oil in the cooler. That is for that car by far the biggest reservoir that doesnt get emptied on an oil change. (apart from when you count that 370ml, I guess the amount in the cooler will be something like that too, maybe 1L max)
