We would need someone close to Clearwater Florida for the R&D
Advantages of Carbon Fiber
•Lighter than steel or aluminum.
•Three times torsional strength of steel.
•Torsional spring rate allows better tire hook-up.
•Torsional spring rate allows smoother shifting.
•Less shock load to the differential.
•Eliminates or dampens high speed vibrations.
•Reduces transmission and differential breakage.
•Characteristics can be varied by changing the wind, angles or diameter. PST offers both steel and 7075 Billet Aluminum yokes.
•In drag racing applications - a better 60 Ft. time.
•ET's have been lowered in some cases by as much as .120.
•In stock car racing better control out of corners is the result of the torsional spring rate.
•In road racing smoother shifting and better durability of transmission and differential have been reported.
•Tested on Cobra's at 180 MPH on Dyno with no vibrations.
•A much greater safety factor - carbon fiber will return to a fiber and not create shrapnel under the car, as would aluminum or steel shafts.
