      12-02-2011, 02:28 PM   #66
sabbanick
Drives: 08 SBM M coupe
Originally Posted by RandysV10 View Post
The calibration is performed when you have the Solo connected to your laptop using RS2.
got it, I'm going to give it a try right now... i'll update post with my results
OK, I'm back
So under live recordings via the ONLINE tab in RS2 the gear data is coming up as ERROR. When I go into solo to reset the gear calibration, Rs2 is telling me that the USB driver is not updated ... seems like an easy fix, but the driver for USB is updated and I restarted to computer to be sure. Result is the same.
Randy did you finally get the Solo DL to read your gears?
