      11-26-2016, 10:21 PM   #16
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Originally Posted by JJZ4MR View Post
I'm VERY GRATEFUL FOR ALL THE THE ADVICE Thank you all ! Nice to reach out. I'm stuck between the RE-71 and the RE -11 Under the advice of this forum and much additional research I'm between these two, RE -71 / 11. They are priced the nearly the same, tough to find available and have similar stats. Anyone have any wisdom/experience to share. Went to my local Tires Plus, $ 999.76 out the door. I asked for any other suggestions, he offered none. I loved my Nitto's, anyone try the NT-05's ? I could save a few hundred $.
Thanks JJ Going with F 235/40 / R 265/35
PS - Everyone agree best for my 06 Z4MR 18 OEM ?
Usually the Nitto NT series perform best when they're absolutely smoking hot which makes them a terrible tire for autocross if you have that in mind. It's also the reason they do poorly wet because even under heavy braking or cornering loads the water keeps them below their best grip temperature.
Top Down 365
