      05-17-2011, 04:33 PM   #10
CobraR1339
Drives: M Coupe SG
Good luck with the track day. Keep us posted.
Being tenatious should reward you. Looks like you are dropping 3 lbs per front corner and 4 lbs per rear corner. That combo and the added grip should get you addicted to the Hoosiers.
Any insights on the NT01's.. sizes suggested above. I think I am stuck with the3 front size on stock rims, but the rear I am not sure if the taller size would create or solve issue with the 1" rake.
